jhdeval
Ok so I need some help. I had an accident a while back and got screwed by a body shop and am now left to fix the damage on my own.
I smashed the front drivers edge so what I am looking for is measurements from each fender body bolt across from each other. There are 5 bolts that hold the fender to the inner fender structure. I would like a measurement from right in front of each bolt to the corresponding bolt on the other side.
I am pretty sure my inner fender on the driver side is tweaked and am trying to figure out how bad and what I can do to fix it. I am hoping I will be able to just pull it because I think it is just an inch or less off but if it's more then that then I don't know if pulling will work.
