65 Barracuda daily driver
In my last post I mentioned that the transmission shifts weird and possibly needs a band adjustment, right?
I just came across this photo that I took when I was dealing with that leaky neutral safety switch. You can see that the front band adjustment lock nut is not touching the transmission case, so it's likely completely loose?! :BangHead:
AP1GczPAqbpyvffefoCE5aKKEJiAlIVCqgtv4Fy_Nl446EFaEUsBibgKAPyRhKJs23kapmBUzrwOIdcEnuOx9Lb1S3ICUwFPbgJE6b7RYnqxPEbrT0RlORZ5TNzKjwdRLO8WuSqF2Zg3epBDsTe8mfWpPJ_-3g=w791-h1054-s-no-gm
I will tackle that this as soon as possible. So I read that you are supposed to tighten the stud to 72 in lbs (6ft lbs) and then back off 2 or 2 1/2 turns and tighten the lock nut.
'65 manual says 2 turns for 273 V8
Also, did I just get 21.56 MPG with a small block??? Previously I had gotten maybe 13 mpg tops. I started taking photos of the pump and the odometer every time I put gas in the car, or did I forget one? Seriously confused. Even the slant 6 before only got 16-18 mpg. Could it be that that last metering rod change had such an impact? I have to keep an eye on that
AP1GczPOikeQxxFnFGTLFYu6GKGMEwP3F1K0PuB0rQq-C8eR8BMHoIQeJnlJEiTcW7UdBTDSr7My8R3Y2S7kyQ1BgHtz68pT3_8h6fcIlOiAsWIAO8X-E9EA6d1Dki6MQ3EEFdJViaSNARsoHcC9ciVC5kyDtw=w791-h1054-s-no-gm
AP1GczMw9pZaDPkyiZ50j6pWyxWucGgHdTtwOwQbzx2NU-9O9aCAnY4ys68-24jVJ6t2hNTMEoYEJ4WkPVGU1iBkxCJFuCb-8C8MvqaDxa7IQBGFkvxVyFFry00ZiVdlaVbgLcZ5nwscV_0EPL7emTwPqnXRbw=w1405-h1054-s-no-gm
AP1GczOS0FfIs2pzuwusv7U-6LiS1S5AdnMI1uIn7ajd4zBi3rUVS2XMesnu2HOJu015MbHEiv3EZclEZ7WECy0mdl8MvSMza5QH5nWjDwsb79ysZE2-UZja1prht5WnzC8UVjwOJCT2tlSclbYn6rRSFTj_eA=w791-h1054-s-no-gm
