A andy l Well-Known Member Joined Aug 18, 2009 Messages 144 Reaction score 0 Location usa Apr 4, 2010 #1 I have a question I put the top down on my convert and it would not go back up till I helped it half way up any ideas. The motor works and there are no leaks I can see
64conv65hard FABO Gold Member FABO Gold Member Joined Jan 16, 2009 Messages 885 Reaction score 568 Location germantown md Apr 4, 2010 #2 Can you hear the motor running while it won't go up? If yes, check fluid level. If no, check electrical feed or make sure the ground is good.
A andy l Well-Known Member Joined Aug 18, 2009 Messages 144 Reaction score 0 Location usa Apr 6, 2010 #3 yes the motor is running but the top doesn't go up unless you help it so I take it I have top fill it with fluid
64conv65hard FABO Gold Member FABO Gold Member Joined Jan 16, 2009 Messages 885 Reaction score 568 Location germantown md Apr 6, 2010 #4 Glad it is an inexpensive fix. Thanks for writing an update, I was wondering what you found.
