Apr 4, 2010 #1 A andy l Well-Known Member Joined Aug 18, 2009 Messages 144 Reaction score 0 Location usa I have a question I put the top down on my convert and it would not go back up till I helped it half way up any ideas. The motor works and there are no leaks I can see
Apr 4, 2010 #2 64conv65hard FABO Gold Member FABO Gold Member Joined Jan 16, 2009 Messages 885 Reaction score 567 Location germantown md Can you hear the motor running while it won't go up? If yes, check fluid level. If no, check electrical feed or make sure the ground is good.
Apr 6, 2010 #3 A andy l Well-Known Member Joined Aug 18, 2009 Messages 144 Reaction score 0 Location usa yes the motor is running but the top doesn't go up unless you help it so I take it I have top fill it with fluid
Apr 6, 2010 #4 64conv65hard FABO Gold Member FABO Gold Member Joined Jan 16, 2009 Messages 885 Reaction score 567 Location germantown md Glad it is an inexpensive fix. Thanks for writing an update, I was wondering what you found.
