You are probably right! I think they must have been very practic for farmers, contractors and service stations world wide.i think the Utes were strictly a product of Australia; I have never heard of any from Siuth Africa or South America.
Yes we have plenty of utes down here..i think the Utes were strictly a product of Australia; I have never heard of any from Siuth Africa or South America.
I can start to see a little dot of light at the end of the tunnel, so I guess it’ll turn out OK!
That little dot of light is starting to get a little brighter and a little bigger! After using my combo flanger/hole punch to punch 60 plus holes around the perimeter of that big passenger side panel, got it spot welded in place.
Now it’s cleaning up all those spot welds in prep for a skim coat of filler
Even though most of the emphasis has been on the exterior, I can’t forget about the interior. I used the upper door sill from the rear doors on each side to give it some continuity from the front doors to where it continues over the wheel wells. Where the rear door skins are mounted, I made a somewhat oversized paper pattern of the opening and copied it to sheet metal. Prior to the start of the installation, I also cut out each panel for the new Pioneer 6x9 speakers I’ve had forever. I’ll use nutcerts to secure the speakers after the interior gets painted. Then it was cut and fit, punch holes around the perimeter to spot weld each one in place. I still need to do the upper inside, which I’ll do after I receive my new 3 point seat belts.
Driver’s side:
Passenger side:
Brand new speaker(s):
I’m dying to see this one come along. Verrry cool indeed.
Hello Don. Pretty darned SPECIAL indeed. Hang in there Don, and it will get done. Can not wait to see its completion. Your interior will be unique as well? I know that the dash is not original to the 65 Dart, as well the front seats. Any special plans for the interior back side area? Keep up the great work. sgrip65
Thanks! Slowly but surely it’s coming together!
Hi Jerry - you are correct! Dash frame is from a 66 Barracuda with the cluster also from a 66. The cluster has been re-worked by Dakota Digital and uses digital gauges. The center of the dash frame has been re-worked to include the power rear window switch, a lighter socket for charging phones, heated front seat switches and idiot lights for DOOR AJAR and FASTEN SEST BELTS (gotta think of safety, right!).
Front and rear folddown rear seat are from a 66 Barracuda covered in the 66 Barracuda pattern but in the 65 metallic blue - special order from Legendary.
I’m waiting on my 3 point seat belts for the front before starting any work on the rear upper side panels- they’ll definitely be finished though.
Well, it’s time to start doing something about the quarter panels. I have plenty of access to the passenger side so that’s where I’ll start. I knew the lower outer skin was riddled with pinholes. Pics taken after removal to get better access to the inner panel.
View attachment 1715462075 View attachment 1715462076
and I could see by the wheel lip a pretty big rust hole on the inner panel.
The rest of the inner panel looked good. I will coat it with POR15.
Fabricated a patch panel for the inner panel. 3 different bends on this baby!View attachment 1715462077
After cleaning up the inner panel, it will get this welded in, then see what I can do about the outer quarter panel. I have an idea or two about them. I will post my solution once I see it will work.
I contacted Rick@Laysons for some good pics of the 65 Valiant/Barracuda lower quarter panel repair patches. It appears they rolled under the quarter panel just like the wagon’s and the shape was the same other than right at the wheelwell lip.. I figured Nothing ventured nothing gained. I ordered both sides just prior to their 20% off sale which ended Dec31st and they didn’t look like they would work out, I’ll return them or sell them. After fitting them I found the wagon quarters are about 2 or 3 inches longer in length than the repair panels at the wheelwell. If I moved the patch panel forward to the wheel lip and trimmed at the back where there were no pin holes, it will fit. Tacked in place:
And pretty much now in place other than some filling a couple of holes and minor grinding:
Hi Jerry - the back seat is done as in reupholstered. Prior to doing the upholstery I did fit and install both the bottom and seat back cores to the wagon. The Barracuda seat back bolts right to the built-in studs on the wheelwell as long as the Barracuda brackets are used. The front seats are waiting to get reupholstered. Both fronts will get heated cushions and seat backs for those cold winter drives. The driver’s seat is getting an adjustable lumbar support for my back.
No show car circuit as I intend to drive and enjoy it for as long as I can.
I know that the early A is gonna require some major floorpan and crossmember mods to fit an A500. I after looking at the upper crossmember at a Barracuda carcass I had, I thought that if I cut it out and modified it, it just might work with some modifications. So I removed the center part of the part of the upper crossmember, then sliced it in half in the middle and added new metal so that it had plenty of room around the A500 transmission where the lower transmission support is mounted. It leaves an inch or so clearance on the sides of the A500. I think I could adjust the height during installation to the crossmember in the wagon.
You're doing great fabrications Don! It will turn out great.Well, that’s what I get for thinking that I could adjust the height of the crossmember during installation! I need around another 2 inches of clearance at the top to clear the transmission. I made a paper pattern of what I already constructed and added 2 inches on the pattern to both sides. The very top of the crossmember also needs to be shortened since the sides are going to be lengthened. Got it all assembled and welded together and test fit to the transmission - plenty of room to the sides and top of the transmission.
To fabricate the lower transmission support I think it will be prudent to assemble the transmission to the motor and motor to the K Frame so that the exact front to back transmission relationship to the new lower support is exact.
Next is to start fabricating a new tunnel. For ease of fabrication I think it will need to be constructed in several sections and welded together.
Great work, It's amazing how much bigger the rear of the trans is for the OD unit.
What's the gear ratio? 0.85?Yes that sucker is much bigger than a 904 or 727 is the azz end
