Or heat that old punch with the torch and poke it thru the hole?
that’s the way we did it from underneath where you can see the holes
Looks great with those heated seat switches but your car will stand out in those Magnum 500 wheels!I did finish the trim and the bar that lets you lower the seat. The machine bolts I used on the brackets is the same length as the originals but stainless instead
Got the reproduction console lights installed snd drilled the mounting hole for the heated seat switches just to the front of the lights. As they are black, they trnd to blend in with the console
finally with the leaky rear end hopefully solved and all reassembled, i wanted to see what the it would look like with the Magnum 500 installed. Bear in mind the wagon is still on jack stands so the tire is lower than it would be if it was on the groundView attachment 1715802304
while it was in the air my buddy went underneath with my portable butane torch and a punch and heated it up and punched through the carpet for the seat holes, the seat belt holes and gas pedal holes. The heated punch kind of melts the carpet and doesn't unravel the carpet like a drill bit would.
I think you have done a great choise!I’ve always loved the Magnum 500’s on the B Bodies. since I had them for a long gone 67 Charger, why not use them on my 65 especially since these 14’s do clear the rear disc calipers!
Good morning my friend! This is what you are missing. The rubber grommet that the fuel pipe go throught. I put it in a padded envelope and ship today.I finished installing the Holley combination sending unit/fuel injection (model # 12-319) which is for 63-76 A bodies to ny reproduction gas tank. The install was fairly straightforward - Holley uses a porous mat called a HydraMat which provides fuel to the pump in low fuel situations (the yellowish thing on the far right). It is installed to the inlet fitting at the bottom of the fuel pump. Then per the instructions the sending unit/float assembly is removed from its bracket on the fuel line tube to facilitate installation. The mat is installed first followed by the pump. Then the sending unit is re-attached to it’s mounting bracket and fed into the opening. After installing the gasket to seal the unit, then the lock ring gets installed. The wiring is straightforward with the pump ground to the battery, another ground for the sending unit, a wire to the gas gauge, and a power wire to a Bosch-style relay which is (user supplied). Holley Tech Support recommends using the Sniper’s built in relay to trigger the fuel pump relay.
Today was tank install day so got my buddy to stop by since he’d volunteered to assist in the installation.
Tank was almost ready to hoist in place after the new tank seal installed. I nearly forgot to install some tank to floor cushioning.
With the tar paper cushion glued on, the tank is now ready to install
The new floor seal from DMT needs to be slid on the filler pipe prior to installing the filler pipe into the tank. With a little WD40at the tank seal, the pipe sort of slid on in (it was definitely a 2 person job working with the filler pipe and jockeying the tank around at the same time! I need the proper size stainless steel screws to secure the floor seal.
Not shown is the filler pipe to quarter panel seal - also from DMT. Until i can get the right size stainless steel screws, i used a couple of regular screws to secure the filler pipe flange to the quarter panel
With the filler tube installed, it appears there’s some kind of plate or seal that is mounted on the inside. there are screw holes so something must go there! I don’t recall removing one. Anyone following this build who has a wagon (@65dartcharger ) have any pics of what I’m missing? There is a wagon in a junkyard about 40 mikes from here that hopefully has this missing part!
Don, Very nice looking work and great documentation. I noticed that your custom tank does not have the appearance of galvanized metal as mine was. What is the finish on your your tank? Thanks for posting. Sgrip65
Where’d you get the tank from?
Yes, with a metal plate casted in it. I posted it 1 hour ago. 5 to 7 days according the postoffice.Hi Jerry - i was wondering about that myself. My buddy who was helping me (my paint/bodyman friend) said it was some kind of epoxy finish that didn’t scratch very easy. It appears the Inside is galvanized or similar.
i did some checking online and bought it from carparts.com which happens to be from/or a subsidiary of J.C. Whitney. It seems to be identical to the original in every respect even though it was made in Taiwan.
Thank you Ulf. It looks like it might be made of rubber?
Yeah, nothing more frustrating than repeating a job like that. Best to do it right though.Much as I hate to, the tank and filler tube will need to come back out to install that seal! One step forward 3 backwards lol!
The electronic harness from the sending unit, is it positive and ground?I finished installing the Holley combination sending unit/fuel injection (model # 12-319) which is for 63-76 A bodies to ny reproduction gas tank. The install was fairly straightforward - Holley uses a porous mat called a HydraMat which provides fuel to the pump in low fuel situations (the yellowish thing on the far right). It is installed to the inlet fitting at the bottom of the fuel pump. Then per the instructions the sending unit/float assembly is removed from its bracket on the fuel line tube to facilitate installation. The mat is installed first followed by the pump. Then the sending unit is re-attached to it’s mounting bracket and fed into the opening. After installing the gasket to seal the unit, then the lock ring gets installed. The wiring is straightforward with the pump ground to the battery, another ground for the sending unit, a wire to the gas gauge, and a power wire to a Bosch-style relay which is (user supplied). Holley Tech Support recommends using the Sniper’s built in relay to trigger the fuel pump relay.
Yes please I'm about to do this.If anyone wants to see the instructions for the fuel pump sending unit combo, I will be happy to post pics of the information
