65 dodge dart gas pedal location v8
FABO Welcome Wagon
  1. dazedand confused
    dazedand confused Well-Known Member
    155
    35
    Oct 3, 2010
    hollister mo.
    Local Time:
    5:17 PM
    I have a 1965 dodge dart that came from the factory with slant 6 1 barrel carb and an automatic tranny shift on the column . Im getting ready to switch over to a modified 360 and it still has the slant 6 throttle pedal set up. I would like to switch over to the stock v8 throttle pedal set up if its not too expensive other wise i have a v8 throttle pedal with bracket for a 74 a-body car that i can install but dont know where to install the set up on the firewall?? Does anyone have a factory v8 set up? Anybody have photos to show me where either one needs to go? Both sides of fire wall etc thanks
  2. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    64,404
    37357
    Jun 7, 2010
    Georgia
    Local Time:
    6:17 PM
    The indensions are already in the floor for the factory V8 setup.
  3. Charrlie_S
    Charrlie_S Well-Known Member
    3,009
    841
    Oct 17, 2005
    Silver Springs, FL
    Local Time:
    6:17 PM
    Yep, just went through this on my 64 Valiant
  4. flingdingo
    flingdingo Well-Known Member
    313
    251
    Apr 26, 2017
    El Lay
    Local Time:
    3:17 PM
    X3. Remove your /6 pedal assembly, peel the insulation back a bit on the firewall and hold the V8 assembly up. Line up the hole the cable goes through with the big hole in the firewall and you'll see the indents.
