There are a lot of picture here 66 Barracuda header and exhaust upgrade
This was right after installation when we were all a little younger
Manual steering only on the Magnum manifolds... sounded like OP was going with power steering.Hedman will make you a set of Husslers for ~$600 now, that is like half price of some of the other headers out there. They are full fenderwells though but probably outflow anything under the chassis. There is a thread here that mentioned that price and how they are special order, no refunds. Have you considered Magnum logs? Flow well, compact and cheap. get the early 2 1/8 outlet models.
Sweeeeet 66 ddarts ! any specs/details on the 273 build ...we All would sure appreciate ? I'm looking to build a stout 273 as well as others do too.I have 2 real D/Darts. One has a modified 273 race engine with some unknown fenderwell headers. The other has a 380 hp 360 Mopar Magnum crate engine with Doug's D450 headers. Supposedly, the crate engines were putting out around 405 hp so it would be around your build. With that much hp, I would go with the Doug's. They are pretty easy to install. I did have to shim the motor mounts up a little bit. There are a could videos on YouTube of me backing them out of my garage. Look under 1966 LO23.
I bet you have see this one .
Awesome cars you guys Have !T
This is Tracey's car. He is a member here. It is a true D/Dart and is currently raced in and around Texas in vintage road race events.
I have no idea what was done with the engine. I was able to find and install the original carb, carb spacer, choke cable and air cleaner assembly. All are one off parts. I believe it has a higher lift cam than what came in the car. The tortion bar cross car bracket was hacked up to get the unknown brand headers it. I would not go that route.Sweeeeet 66 ddarts ! any specs/details on the 273 build ...we All would sure appreciate ? I'm looking to build a stout 273 as well as others do too.
I thought the 66 D-Dart came with the dougs headers in the trunk from the factory.
Anyone know if hedman made 1 5/8" fender wells headers for early abodies ?I new a guy, John B. back in the early 70's that had a 67 Dart GT 273 4 barrel, auto trans. Him and a real good buddy of mine Bob V. built that car into a low 13 screamer, the engine had home ported heads by John, and if I remember right it had around 12 to 12.5 to 1 compression, .500+ lift solid lifter cam, 1 5/8 cheepy headers, a Fairbanks converter, and a reverse manual valve body in the 904, and 4.30 gears in the 8 3/4, with 8.00/14 cheater slicks, and it was always shifted well north of 7 grand. That Dart put quite a few 327 and 350 Camaro's and Novas to shame. It was a fun car to ride around in on a Friday or Saturday night.
P.S. My vote is the Doug's 1 5/8 D-450 Headers or if you don't mind cutting out the fender wells, see if you could order a set of Hedman Husler 1 5/8 fender wells.
I don't believe it's a 273. @ddartdude would know for sure.Is there a few of these? I swear about 2 years ago at Lebanon Valley that car was in the car show during the Mopar Sunday.
Lebanon Valley, NY approx Sept mid month. I should look as I took a few pics of that car.
I have 11 in my registry that still exist. I want to say that Tracey is running a 340 in the race car. That car has been 'for sale' all over the country. I believe he bought it from a dealer in Connecticut.I don't believe it's a 273. @ddartdude would know for sure.
well your engine is no long to 273 specs ....4" bore... it's a 340Status update:
So I ordered Doug’s D450 ceramic coated on Friday and was told 6-8 week wait. Bummer but I get it.
Here are a few photos of the engine. I got a few things wrong with original thoughts of the work being done at Larry’s machine shop on Groton, CT. Here is what was done so far to the engine.
Custom pistons- rings are grouped closer together and ring tension is 18lbs vs factory 27lbs.
Piston skirts were shortend- pistons are forged. 11.0-1 then valve notches added.
Block was squared up to Insain measures before .040” bore was done.
Rotating assembly was lightened and crank balanced - more weight was removed from crank due to pistons are so light.
Heads are next but not completed- waiting on mechanical cam to arrive to set valve spring pressures. Those are the closed chamber early 273 heads - bowls polished, ports cleaned up and new valves seats viton seals. View attachment 1715728288View attachment 1715728289View attachment 1715728290View attachment 1715728291View attachment 1715728292
