66 barracuda formula s heading to crusher
Im always looking for inner fenderwells but shipping from Canada is a no go.
Yeah living in Canada will be the tough part getting rid of the parts shipping can get costly, being that it's a 4 speed console car what do you think would be a fair starting price for all the the 4 speed stuff together, pedals, floor hump trans flywheel all linkage, z bar shifter and even the original hurst consol shifter or should one sell it separately?
I also talked to my buddy some more and he is going to strip pretty much everything he can, so if you need anything pm me and let me know the rest wil eventually end up in the classifieds, I understand shipping from Canada sucks trust me it costs me double to build my duster and my other projects up here with shipping and our crappy dollar, so all parts will be very reasonably priced. small parts shipping isn't to bad but big heavy stuff can get expensive
Those manis are a bolt in for a 340/360 into a 64-66 but power steering is a grind. Look at pass side for a tri-Y shape. Thats the money.
I'm first up on the left, right & center grill sections!!! Let me know!!!
That is not the original shifter, the original would be an Inland with the reverse lockout collar! I would be willing to bet the entire drivetrain has been replaced with a later setup! A look at the trans would certainly tell the tale, and make a big difference in the price!
dam you got 5000.00worth of parts there don't scrap a 1 year only car
the tail light quarters theres way toomuch to save save it all I will by the whole car for 150.00
all those plastic tabs for the the rocker chrome areal ways missing t some 1 screwed it back on because they couldn't find the plastic tabs
hat's why rocker chrome always has 2 holes drilled in it DUDE its 66 BARRACUDA MADE 1 YEAR ONLY
IF ITS A FORMULA S I want the front spindles and disc brakes pull the rear seat see what it really is on the build sheet
light switches radio knobs if not a delete wiper knobs , seat frames , window rails interior panels wiring , I want the prop rod for the trunk please K frame so many parts
I will take the sway bar got an antenna prob junk fire wall wire clips carpet over w3heel wells rear carpet I need the plastic trunklock cover , dude icould go on 1 peiceat a time , I got nothing but time air cleaner valve covers rocker arm assembly vaccum canister if had 1 anybadges trunkhinge chrome gas cap radiator door rubbers
z bar
emergency breake gas tankwire under carpet . door seals horn ring and cap steering column , coat hangers, little stuff the hardest to find
Good thread. If you start parting it out let a moderator know and we can change this thread to "parts for sale" or you can start a new sale thread. Scrapping out these old cars is good for the hobby. No reason for good parts to go to the crusher. tmm
200.00 I take it all you load iwill haul
