66 barracuda formula s heading to crusher
Make sure you grab the tach can from under the drivers side kick panel! And the rear window plastic trim pieces on the inside corners, the rear seat hinge lock bezels, the drivers side fresh air box, the entire gas pedal assembly, the trans crossmember for me, the trunk lid prop rod, the fold down panel for the trunk pass thru...aw heck, just take the whole darn car home and I'll be over to pick it up!!
cos I am up to 225.00
They motor is probably a lot newer.....the manifold and the front water pump and pulleys are all newer stuff. Is the speedometer going to be for sale?
if manual steering, could have the quick ratio box, take the whole k assy.
could also have discs, of course
Hi there hope not too late to the forum.. i do need the center link!! Please save it.. iwould agree to save rhe whole car for parts... hard to get... all the trim pieces .. parts list is wirh no end..
