Challngd73
Yes I plan to drop the car as much as possible to achieve that look. The fronts are 18x8 with 245/40/18 and the rears are 18x9.5 with 275/35/18's.
your hoods not that different to what I'm doing for my 67 Dodge ute….making a mould from mine for a light weight fiberglass hood, factory these are very heavy, far worse now!!
Hey Marty what happened with the valiant?
Yup four years is a while.View attachment 1715227470 View attachment 1715227467 View attachment 1715227468 Been a while since I’ve been on here. Had a number of bad luck issues with the car, with the latest being a cracked cylinder wall in the ATK 408. But I came across a blueprint 408 for a good deal and it’s being installed this week. Then going to the body shop to have some custom work done to get the new hood on. Here’s some updates pics of where she stands now.
Life happensYup four years is a while.
that looks the part...nice to see something other than a reverse cowl scoop!
I absolutely love that hood I want to do something similar to that with mine. Did you just use a aar cuda hood and cut it to get the scoop part out?Back from paint and tucked away for the winter.
Yes, that is exactly what we did. Can’t even tell it’s not the way it came!I absolutely love that hood I want to do something similar to that with mine. Did you just use a aar cuda hood and cut it to get the scoop part out?
I can’t speak to the method my paint guy used, but it is paint, not a wrap.Like what you are doing with your early, how did you attain the flat/gloss in the paint? clear? wrap? or flat/ gloss all the way through?
looks good.
I so want to try that!!Yes, that is exactly what we did. Can’t even tell it’s not the way it came!
