66Dvert
Working on my custom car parts again!
I just finished redoing the inner boards and soldered them up for a test. Looks like I have it nailed this time.
with the lenses hot glued to the housing (no bezels on yet) the alignment looks goooooooood! I did put back in the little clear reflector piece (only 3 so far) since I moved the led's over enough to use them.
full brakes with flash, forgot to turn it off
tails with the flash
tails without the flash
they'll stay in brake mode all night to check out if they'll overheat
it's 75 degrees here and the lights are showing 78 degrees on the digital
I'll check tomorrow afternoon to see how much it climbed in about 16 hours full running of brakes and tails.
