[FOR SALE] 67-72 Dart Gauge Cluster Gaskets
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Gasket set for 67-72 Dart instrument cluster.
Designed from OEM parts, using the same type and thickness foam. Complete with peel and stick adhesive on the back sides, ready to install.
MADE IN THE USA!
The gaskets included in the kit are:
  1. One Oil Warning Light
  2. Two turn signal
  3. One 67-69 Brake Warning Light
  4. One 70-72 Brake Warning Light
  5. Two Fuel Gauge
  6. One ALT Gauge
NOTE: The 70-72 Brake Warning gasket is made from foam, the OEM gasket is made from rubber.
Each kit is $15.00 (US) shipped to a US address.
Payment by PayPal or Zelle
PayPal (I prefer Friends and Family but if you prefer to use PayPal's Purchase Protection that's ok by me)
PM me if you don't have a US address.
Part Identification
Installation photos to follow below.
Install brake warning gasket to the bezel.
Use a razor blade to assist with removing the backing.
67-69
NOTE: The gasket is a parallelogram and should follow the opening.
70-72
Note: The right side of the gasket is slightly angled to follow the opening
Next install the Turn Signal and Oil Warning Light lenses
The lenses should be placed in the cluster open end up as shown
This is the correct way to install
This is not correct
Place the gaskets over the lenses, center as best you can.
At this point this is what you should have.
Next the ALT Gauge
Place the wider foam strip on the right side as shown
NOTE: Protect the face plate and needle, have a helper hold the gauge by the edges as you apply the gasket
CONTINUED....
Next the Fuel Gauge
Place one each of the thin strips on either side of the Fuel Gauge as shown
Final assembly....
Install the speedometer Head
Install the ALT Gauge
Install the Temp Gauge
Install the Fuel Gauge
This is what you should have at this point.
Install the cluster cover
Install the bezel
