To make the power band on a smaller grind come in later in RPM you must retard the timing at the cam.. not advance it- then it comes in sooner and dies off earlier
A question I have though is- Can you use the solid lifter pushrods/rockers with a hyd cam?
I knew that. I wanted to keep the bottom end. Lower rpm's is where I spend most of my time. I'm not really complaining. It runs well I just know there is a lot more performance there without getting too radical. tmm
