67 barracuda rim/tire question
67/6barracuda
Sharpsburg, GA
Hi guys I know its probably been asked before but will these rims and tires fit my 67 barracuda. I plan on using the wheel spacers from summit. Because i have the 4" small bolt pattern but will eventually upgrade to the larger bolt pattern.
Mag wheels are 14 x 6 with 4.5 inch bolt pattern, $149.00 for the set of 4 (includes center caps).
Tires are 225/70/SR14, free to the buyer of the mag wheels.
It would depend on what the back spacing of the wheels are and how thick your adapters are. Most likely they would fit. If these are the chrome steel wheels be sure to check the lug nut holes to make sure they aren't wallowed out as I have had a lot of these wheels that were and wouldn't seat correctly.
