4spd your in box is full. Pm me with price. You could post photos here, but the pc police might bust us.
Checked my 25+ year old harbor freight cen-tech p35017 meter, 0.4 ohms is dead short..4 Ohms seems kindof high to me
Guess that makes my old cheapo Radio Shack Archer multi-meter look good.Checked my 25+ year old harbor freight cen-tech p35017 meter, 0.4 ohms is dead short.
I also fixed the dome light switch contact.
It's the little wins in life!
It had high resistance and intermitnant connectivity.What was wrong with the dome light switch? Just dirt or more involved
There is probably a pot inside I cod adjust. But 0.4 is good enough for what I use it for.Whenever its seems off, check zero and readjust the needle until it lines up.
The digital one is easier to read but can't do that
No.Would the one with a ground pin make any difference over the one with out for the headlight switch?
The other thing to watch out for is the circuit breaker. A-bodies got a switch with a 15 amp circuit breaker. This is because the wires to the headlights are only 18 ga. Other cars/makes/models often used a switch with a 20 amp circuit breaker. It may fit but won't protect when you need it to.There is one difference the one from the smaller resistor is smaller in size, and if on a 67 the pull knob won't fit with the locking nut. Just got the one with the bigger resistor and it won't work
Yes, you are supposed to start a wanted thread if you are searching for used parts.4spd your in box is full. Pm me with price. You could post photos here, but the pc police might bust us.
The protection (fuse, circuit breaker, etc) is sized on the weakest link in the circuit. In theory that's the 18 gage wires to the headlights. In reality its often the terminals and terminal crimps in the connectors. Especially when oxidized.I rewired the car, will have to double check what amp that circut has. Will a stock replacement handle the 20amp? Might need to bypass the switch and just wire the running lights and dash lights to their own switches. Those are the only two circuits that didn't come on with the factory switch I have.
