well mounted the radiator, ecu is also mounted. modifying the bench seat to fit now. just needs welded up and match the old mounting points for the kirkeys i had in it before. engine block is out for oil pan and possibly to the machine shop. im not sure ive got enough money to get pistons and machine work along with short block assembly right this moment. cams is officially ordered, but have to send payment in the am tomorrow.
engine wise eside the pistons, gaskets, head studs, valve spring kit and valve covers. ill have a running engine from their. cars damn near getting closer and closer. i can almost see some light down this very dark tunnel.
