I will be converting in the near future from drum to disc, and one question I have not found an answer to is this:
Will the finished width be the same, wider, or narrower when I am done? (call the measurement centerline of tire to centerline of tire - and for the argument, assume rim/tire combo of same dimensions used)
I would assume if I was putting on a stock 67 disc package, the width would be the same - but I was not sure about the 73 and up disc setups.
Thank you
Thank you
