Matts440
Well with turning up the fuel psi now I go way rich at 4k so time to take a lot of fuel back out.
Sounds like you found the problem. I bet the flow curve on those injectors isn't linear when below the specified psi. I would continue to monitor psi, and duty cycle just in case. Good luck!Well with turning up the fuel psi now I go way rich at 4k so time to take a lot of fuel back out.
Matt this may help.
Thanks, when you data log do you use the high speed one or the data log tab at the top? I've been using the high speed one and it only shows ign and spark.I think it’s an analog input I had to configure and label. I can look it up for you later when I’m in front of my laptop.
You need to figure out what analog input the fuel psi is connected to. Use the data log tab at the top. Make sure you are recording that analog input in the Data log Profile editor. After you collect the data, you can open the file with mega log viewer and check out everything that was recorded.Thanks, when you data log do you use the high speed one or the data log tab at the top? I've been using the high speed one and it only shows ign and spark.
Yeah I've been using the wrong one, insert forehead slap emogi, next time I'm out I'll use that one, I looked at that one and what it logs and it shows fuel pressure, I know its wire spare abc, checked that last night. Thanks for the help.You need to figure out what analog input the fuel psi is connected to. Use the data log tab at the top. Make sure you are recording that analog input in the Data log Profile editor. After you collect the data, you can open the file with mega log viewer and check out everything that was recorded.
I do have the license of tuner have not done the mega viewer yet now I know where to look I'll check it out when I get home tonight make sure its in and ready for the next drive.The Lowdoller fuel pressure sensor is configured in analog inputs. Once enabled and labeled you should be able to capture it in your logging and view it when importing the log into MegaLogViewer. If you haven't already, I recommend buying the licensed versions of both TunerStudio and Megalogviewer. The extra features are worth it.
True or come up with a electronic fuel pressure regulator that it can just adjust the pressure as neededI’ll never understand why these ECU’s can’t compensate for fuel pressure given the fact that fuel pressure is an input to the ecu and the rest is just math to calculate injector pulse width.... sigh... lol
If you have the o2 correction percentage set high enough it will compensate for dropping fuel pressure. But I’m sure you knew that.I’ll never understand why these ECU’s can’t compensate for fuel pressure given the fact that fuel pressure is an input to the ecu and the rest is just math to calculate injector pulse width.... sigh... lol
What it's all really about. Proud dad moment indeed.Didn't get around to driving the dart this weekend to check the new setting I uploaded, but did have some proud daddy day with my oldest working on his motor for the 68 Valiant we picked up for him.
Thanks, me too lol first one will be horrible I'm betting since it's at the track not the street lolI’ve been watching this build since day one. Can’t wait to see some numbers from the track
That door bar looks really high. I think the rule states it is supposed to pass between your shoulder and elbow. Is that where it lands?Sorry haven't updated in a long time, been waiting for a family friend to come and help with some new roll cage bars, plus had another guy offer to help but never did, but tune is about there, hitting the track this year we start up here in March. Had to move my drivers door bar up so ordered that and added a X brace to the back. Got the racing gear for christmas this last year so jacket, pants m, shoes, neck collar and new helmet ready, new sfi seat belt working on trans shield, going to get the TCI one. Then it will be ready for the track. Have the aluminum coming to finish the rear firewall to the trunk. Plus working on my son's car too been busy lol
Yep, it's a little on the higher side but falls between there. On me, I can move the seat up a bit for racing and it will lower it down more, the seat placement there is just for the street. Usually for racing I move closer like 1-2 clicks forward just. Still need the brace for the seat to bar.That door bar looks really high. I think the rule states it is supposed to pass between your shoulder and elbow. Is that where it lands?
