Message sentI have 68 two door parts car a 68 4 door parts car Witch is pretty solid and two 69 darts for parts located in anderson s.c.View attachment 1715691983 View attachment 1715691984 View attachment 1715691985 View attachment 1715691987
No bucket seatsany of those 2 dr's have any bucket seats, were they BB cars?
Let me see if I can get you some. To be sure, we are talking about the white plastic squares that hold the trim on a GT, correct?Hello, I’m restoring a 69 gt in France and i’m after the 69 upper body trim (plastic) fasteners. I collected so far 25 out of the 40 something required. Would you sell those?
I have a complete antenna from a 72 dart if that works for youNeeding the antenna (complete) off of the green car. Do you still have it?
On the 1968 driver side quarter window there is a bracket inside that the glass mounts to and the bracket mounts to the window regulator I need that bracket can I get a price and shipping to 19709 thank you it would be on the 68 2 door hardtop carI have 68 two door parts car a 68 4 door parts car Witch is pretty solid and two 69 darts for parts located in anderson s.c.View attachment 1715691983 View attachment 1715691984 View attachment 1715691985 View attachment 1715691987
None of them have radiatorsAre auto or manual trans, looking for radiator part number on top tank 2949065
Is the bracket on the lower end of the glass?On the 1968 driver side quarter window there is a bracket inside that the glass mounts to and the bracket mounts to the window regulator I need that bracket can I get a price and shipping to 19709 thank you it would be on the 68 2 door hardtop car
No it's not the bracket on the lower edge of the glassIs the bracket on the lower end of the glass?
Hi sorry I’m just seeing your post now... yes that’s the ones, the upper trims going front to end only on 69 gt. As said there should be around 40 of them on both side. Thanks for checking that for meLet me see if I can get you some. To be sure, we are talking about the white plastic squares that hold the trim on a GT, correct?
do you happen to have a picture, I know you need one so u might not have it, the aluminum with slides for rollers I might have a picture of oneNo it's not the bracket on the lower edge of the glass
Its a 4 door. I will check.Are the outter door handles in good condition?
I don't have any antennasI am looking radio antenna complete
Your inbox is full. I'd like to send you a PM.I don't have any antennas
Do you have a complete wiper assembly with motor, scissor arms and wiper armsYour inbox is full. I'd like to send you a PM.
It dosnt have a antennaNeeding the antenna (complete) off of the green car. Do you still have it?
I don't they are missingOn the two door, do you have the aluminum trim that the door panels slide up into on the interior side?
Ok, thanks!I don't they are missing
