I need this section of the frame, if possible. *passenger side only*
Years ago when I ran Hooker fenderwell headers a section of frame needed to be notched...well a friend went nuts with his plasma cutter and removed way too much. This section is in line with the the trans crossmember, but between the main frame and rocker. Need as large a piece as can be removed.
Thanks!!
Do you happen to have the interior chrome channel that runs above/along the roof rail weatherstrip for each side and the metal body colored interior trim beside them (along the edge of the headliner) for a 2 door?
I may have asked about this before in a PM but saw the thread and thought I'd double check. I'm looking for this brace inside the trunk on the driver's side. It is just above the trunk drop-off and goes to the rear panel for the back bumper. I'm looking for then entire brace, in the blue circle and indicated by the red arrow. Mine is rotten at the green arrow.
