Jeff,How the bloody hell are you gonna fit exhaust on that?!!!
Jeff
Going to put the headers in this weekend. The hardest part will be the tail pipes. I have a vision in my head, hopefully it works.
Jeff
Jeff,
....... I have a vision in my head, hopefully it works.
I know scaryRhut-Row
I'll be damned!Headers went in easy and fit awesome!
Thanks, Its been fun working on this Hot Rod. I cannot wait to go down the road again.A plus on the install. Gonna be a fun ride.
When using the 1" extenders, I usually have to take approximately 1" off the tie rod (threaded end) . The 1" extenders are more like 1-1/2" to 1-3/4" extendersI pulled everything back apart, Painted the motor Race Hemi Orange and powder coated the front end.
I went with the 325 spring and single adjuster coil over shocks. Just a couple of small things left to do on the suspension. The steering, the rack is not long enough so I have extenders and now too long, so dealing with that. The sway bar just have to finish up the links.
The stance is good with the motor in. Hopefully the rear will lower some more when all the weight is in the car.
