Why 6v?apply 6v to the board and see if they light up
Why 6v?
Only the gauges do, the bulbs are 12v.Because that's what the board operates off of 5-6v. 12 into regulator and 5-6 out. You know that
Hi Dana, I literally have nothing to plug into the area you have kindly highlighted... Can you please advise what exactly I need to buy to make these work? I have scoped the CI website, but can't seem to find actual push/pull replacement globes-bulbs or the holders? Also, are the turn signal bulbs wired separately from the circuit board they sit in?
Thanks... I just need to find out where I can get the original style bulbs/holders, I was hoping from CI, as I have to place an order there anyways, and hoping to combine shipping, that costs a small fortune being based here!Once you get your boards repaired, put in bulbs, apply 6v to the board and see if they light up. Replacing the voltage reg for the board is a good idea.
I just made my dash harness and installed LED's they look good, just make sure they are oriented(polarity specific) properly.
Hmmmm I though the bulb holders might be easy to source brand new... If it's too hard, I won't bother, now that I think about it, I may be able to source them here in Oz fe the same vintage model Valiant that we had , Tha ks againGlad to help, orig bulbs are 194's, pretty common. The bulb holders themselves can be very frustrating to find, as there are some that are "close", BUT are wrong and dont stay in the hole properly. Make sure whichever ones you find that they confirm correct. OR if(and I suggest you do) you send your boards to Moparmike, that he may have bulb holders? I have a few but to ship just bulb holders is foolish lol.
Thanks so much - I'll check them out!From Amazon...
Retro-Motive 5/8" Dash Bulb Sockets with #194 Bulbs Fits GM Ford & Mopar (Qty-10 Sockets & 10 Bulbs) #1565 https://a.co/d/2kUYyvD
I have not bought these myself but 5/8" is the size you need.
Hi Mattax, thanks for your input, I just checked the chart on CI website and is seems you are correct, it does indeed specify 158 as the bulb numbers for my 68 Dart... I guess that means the link provided previously to the holders/bulbs on Amazon may not be correct for my application?My recollection is the correct bulbfor instrument lighting is 158.
Check your owners manual, or faciling that, the FSM.
IIRC 194 was used later on for outside side markers.
In particular for the turn signal indicator bulbs it is important to have the correct ones so the flasher unit work at the proper rate.
The bulb holders are common, although quality of the replacements vary...
I check the factory books first 'cause that time is well worth avoiding ot worth the hassle and cost.Hi Mattax, thanks for your input, I just checked the chart on CI website and is seems you are correct, it does indeed specify 158 as the bulb numbers for my 68 Dart... I guess that means the link provided previously to the holders/bulbs on Amazon may not be correct for my application?
Awesome, as I don't have a factory book, ...but it may be in my owners manual actually, i can double check tomorrowI check the factory books first 'cause that time is well worth avoiding ot worth the hassle and cost.
Holder's. Hold On. Lemme get a screen shot from lamp catalog and maybe some photos.
Owners book is often better for lamps anyway.Awesome, as I don't have a factory book, ...but it may be in my owners manual actually, i can double check tomorrow![]()
AnswerOkay, I actually just found this thread, that says 194s can be used, they're just a bit stronger/brighter... I is getting confused
Instrument panel bulbs
The aftermarket would much prefer you buy one size fits most, works just the same for us, performing as intended not our concern, why do you care it an old car, and this way we only have to stock one part....In particular for the turn signal indicator bulbs it is important to have the correct ones so the flasher unit work at the proper rate.
Thanks... I've found 158's through CI, and will just use those to be safe...Look do yourself a favor.........look in the FACTORY MANUAL and find out what lamps are SUPPOSED to be in the cluster, then look up any substitutes you are considering and COMPARE WATTAGE ratings, because you can melt the nice little tinted diffusers inside the cluster.
EG 158 is .24A @14V / 3.6watt
194 is .27A @ 14V / 3.78W
Now those two examples may not be significant, but there may be others
Hey Dana, I have ordered the RT IVR as kindly advised by yourself, was wondering, does this now mean I can do away with the capacitor, and simply run the new solid state VR?BTW
If it was me...
I would get both boards, and a r-t engineering IVR
RTE limiter - rte
I have to pull my cluster because my OEM ivr died and fried my temp gauge.
When the heater wire in the IVR breaks the IVR provided 12v continuous to the gauges.
You don't have much to loose trying to fix it.
I like the brass pin nail repair, just watch the heat so you don't delaminate the copper traces off the board.
You could re-engineer it. Solder wires to the board, and create an appropriate pin on the end of each wire that will connect up to the stock connector in the wiring harness.
Be sure no exposed conductors.
