mygasser
that looks nice and neat
neil.
neil.
as long as the car is right side up they'll work just finenice one, will you treat the boot lace brackets with fibreglass resin to stiffen them up some?
neil.
that'll work...... as long as your heels don't get caught in those slots just when you don't want them to. they look to be positioned for just that purpose
neil.
my son just moved to vegas for work, so i figured if it ever got mostly done and can talk my wife into riding in it that long, i'd swing by and see youWhen it's all done I'd do a road trip just to see it in person.
you probably did, someday i'll find it all in a box if i ever get around to organizing everythingNot that it matters now but I thought I gave you all the PS stuff. ?
Not that I remember what we stuffed into your truck.
well if you were fitting a tilt column it made sense to do the electric power setup as you were working in that area anyway. plus it keeps the engine bay cleaner, plus it'll never leak p/s fluid, all good justifications for sureyou probably did, someday i'll find it all in a box if i ever get around to organizing everything
what started this was one of the first things i bought when i got the car was a 16:1 manual box, which was fine until i tore my rotator cuff back in december. that put me back on the P/S not so bad bandwagon, then i figured i'd add a tilt column...
anyway, it all seemed to make some kind of sense at the time
how good they were will be determined when i don't have any problemswell if you were fitting a tilt column it made sense to do the electric power setup as you were working in that area anyway. plus it keeps the engine bay cleaner, plus it'll never leak p/s fluid, all good justifications for sure
neil.
i like that.....they're all much of a muchness.
neil.
