I am sure a lot of you have read the "Welcome" forum on the pursuit of my 'Cuda that I purchase new in 1969. I was able to find and purchase the car and have started on the rebuild/restoration of the car.
I thought I would start a new thread in the restoration forum as to the progress of getting the car on the road again. That may happen yet this year, but next summer is probably reality.
My engine builder just called, the #'s matching block is good! He has bored it .60 and ordered the correct forged pistons. The rods are good, just need to be resized. The heads are good, just need to be rebuilt. Intakes is good and I have sent the AVS off to be rebuilt
I have ordered a Chet Herbert (Doug) cam and kit that is very close to what came in a 68 340 with a 4 speed. That cam was hotter then what came in the 69. It should be a very good street cam.
I have found most of the parts that I need to put the car together. I still need some parts, fan shroud, clutch fork and windshield washer reservoir come to mind.
I tried to post some current photos of the engine before I pulled it, for some reason they would not load. I will try again later.
Pa karp
Pa karp
