340sFastback
Cut out rusted area in floor above rear frame rail and butt welded in some new metal
Thought about a TKX yes and it is a good option - it is a tad smaller, lighter, and a bit cheaper then 6 spd. But I liked the ratios of the 6 spd better and wanted the two over drive gears. T56 Magnum has an outstanding reputation and is known for its shift quality and durability. But I have seen youtube reviews of TKX and people really like how it shifts once they get it installed.
So it boils down to personal preference TKX or T56 Magnum. I would look at gear ratio options between the two, consider size and weight differences, look at price differences, consider which would work best for your car and how you plan to use it ect and decide.
Console w/ shifter
https://www.forabodiesonly.com/mopa...8-4b28-9e03-e5c2e7d58837-jpeg-jpg.1715408171/
Whole process
T56 Magnum and Clutch
Also decided to get sub frame connectors test fitted. Had to grind some off where they go over top of rear frame rails and grind out pre-cut notches for couple of ribs. Then took 2x4 and sledge hammer to strategically tweak the shape of the floor in couple of areas to get the gaps closed up. Fit is really good.
Excellent advice and yes US Car Tool connectors. Prior to welding in new cross member I drilled holes to move emergency brake cable over to come out other side of frame connector. Hooked cable up verified prior to welding in cross member with frame connector held in place so all set there.Just a quick observation.
If you havent welded in your frame connectors yet ( US Cartools??), now is a great time to notch them for your handbrake cable and possibly, gas line.
Cool!Excellent advice and yes US Car Tool connectors. Prior to welding in new cross member I drilled holes to move emergency brake cable over to come out other side of frame connector. Hooked cable up verified prior to welding in cross member with frame connector held in place so all set there.
Brake and fuel lines going to be custom run up inner side of frame connectors. I verified mufflers exhaust are far away plenty of room. I have high end steel line flare and other line tools on hand from prior project.
If I had to do it again I would have bought that rear pan from AMD and cut the corners out of that pan and butt welded them into my car. Would have been far faster easier then what I did.Great work! Wish I lived near by, need the exact same piece for my pass. side.
