During a dash bezel refresh, I ended up knocking the tach needle off.
I "think" I reinserted correctly, but now the tach doesn't work.
Really hoping it is because I flailed on wiring connections, not tach needle issue.
anyone have an image of where the two wires go to the posts on the tach?
it seems simple, but I want to be sure before I remove dash again.
#1 = ~ 16 gauge wire terminated in a crimp on eyelet
#2 = ~ 16 gauge wire terminated in a 90 degree push on connector.
The correct image, similar to the one below would be great.
Yes I searched, that's why I found the image.
Thank you
Craig
Thank you
Craig
