Mouse action
If it were easy everyone would have a hot Rod.
Got a better pic of console upside down? Also a couple of the problem areas on bracket and console. Unfortunately I just reinstalled my console or I could confirm measurements.
Here are the pictures showing the AMD bracket, the console and why it doesn't fit.
You can see that plastic strip which interferes with the bracket going down into place:
View attachment 1715841766 View attachment 1715841765 View attachment 1715841764 View attachment 1715841763
Flip the bracket 180* and try it. The ends get tacked to floor.
Bad news on the 340 block.
The engine guy called today and after hot tanking the block, 6 of 8 cylinders will need sleeving. He wants to do all 8 at this point. So all that plus cam bearings and decking the block will be around $2000.
Weighing my options… I have to call him back soon and let him know if I want to go ahead or scrap the project. :-(
By the time you put a 440 in it, you'll be spending a lot on stuff to make it fit.
Like what, besides motor mount adapters, custom headers, mini starter and disc brakes up front?
Like Steve said, torsion bars. But you'll pile up the bills pretty quickly as that stuff has gotten expensive recently. You'll get close to $2K PDQ. TTI headers $1000, disc brakes figure $300-$800, motor mounts brackets $150 if you can find them, starter $80-$150, torsion bars $325+... Since Schumacher's engine swap stuff isn't available for now, you'd need to scrounge for stuff. Maybe find a Direct Connection big block K-member, also expensive.Like what, besides motor mount adapters, custom headers, mini starter and disc brakes up front?
Will the big block headers fit with the power steering?
I also have air conditioning. Would there be enough room for that as well or would I have to give it up?
