I have a 67 Dart GT ragtop with 13 inch wheels and drums all around. It is a 273 - 2 bbl mated to a stock 904 with a 7-1/4 non sure grip with 2.94 gears.
I have already secured a disk brake setup with BBP for the front.
At this time, nor in the near future, will I be able to afford to swap the rear to 8-3/4, and I am wondering if anyone has successfully and safely drilled BBP holes into their 7-1/4 axles as a temporary fix to get to BBP wheels choices? This way I could buy one set of rims and tires and be good both before and after the 8-3/4 swap. The car will see little to no abuse until I can afford to mod the engine some and swap to 8-3/4.
I have seen 8-3/4 axles which are dual drilled, but I have not seen any 7-1/4.
Any thoughts or experience is appreciated.
Thank you
Thank you
