18 degrees out, 20-25 mph wind, 36 x 28 shop, radiant heater on 2nd lowest thermostat setting, and I walked in and it’s 70 degrees in here.
Dang that thing works great. We need some snow over here to help insulate our house and garage, 70 degrees that would be really nice18 degrees out, 20-25 mph wind, 36 x 28 shop, radiant heater on 2nd lowest thermostat setting, and I walked in and it’s 70 degrees in here.
So I'm contemplating cutting an inch below this black line and making a flange to mount my tunnel. I believe I'll gain an inch of clearance between the floor pan/tunnel and won't get into the gas pedal area, for my trans shield.
I have to add a rocker bar I believe it's called but I will be adding that anyways because of my more than 1 sq foot of floor being replaced.Check your rule book first. I can’t remember how much of that you can take out before you need more bars.
I know when I had to make a foot box for my car it was a giant PITA because I never planned for it and getting enough bars to keep the rules freaks happy was hard to do.
Well, I have to get a transmission blanket and a flex plate shield. Called A&A transmission.
They tried to buy out csr and csr wanted too much money for the company so they said f that and are going to develop their own.
But this will be months out.
I obviously have no idea how fast my car will be but I'm just building it as if it will run in the 9s.
I have a feeling I'm going to making a fairly chubby car with all of the bracing and floor plans but safe is way better than what it was. I think my front spring box would have eventually tore through the floor.
Yes I can't wait to start making progress again.It runs what it runs. Main thing is get out and have fun safely.
Please let us know when they come out with at least the blanket, might be looking to get one.Well, I have to get a transmission blanket and a flex plate shield. Called A&A transmission.
A&a has in stock 2 version of blanket I will be ordering a long which is case to tail shaft.Please let us know when they come out with at least the blanket, might be looking to get one.
Ah, so it’s the flex plate shield they are developing, gotcha. Need to get back to the track when they open back up in feb to see what I run with the engine updates and new torque converter.A&a has in stock 2 version of blanket I will be ordering a long which is case to tail shaft.
Prices aren't too bad, $ 280.00 for the long one if I remember correctly.
They're developing the csr shield which is carbon fiber from the front bell to the case. If you have a blanket it's good to 10s, the steel flex plate shield is additional and necessary for 9s.Ah, so it’s the flex plate shield they are developing, gotcha. Need to get back to the track when they open back up in feb to see what I run with the engine updates and new torque converter.
You can still do your mods without a blanket and allow the expected room. If you look for the build pics of my car I have a ton of tubes in my floor and it's still light. I also have the tunnel and floor 'flanged' around the transmission. At some point it may be easier to do your own floor 'tin' especially if the old floor is cut out. With that said it's difficult to duplicate the 'shear-plate' strength of the factory floor in consideration of weight and integral strength.Well, I have to get a transmission blanket and a flex plate shield. Called A&A transmission.
This was funny. I took a shower this morning and was looking at my wife's shampoo apparently the coconut oil separated from the shampoo because it's so cold upstairs.
I am enjoying this cold , I'm not even kidding.
I
I have an unreliable source of firewood, red fir and 2 fireplaces in the houseI also enjoy 4 seasons. Do you have a source of fire wood? A wood burner would make a fantastic source of additional heat.
Thank you, Do you know what the thread name or names might be? I'm very interested in checking out additional ideas (especially on your car)You can still do your mods without a blanket and allow the expected room. If you look for the build pics of my car I have a ton of tubes in my floor and it's still light. I also have the tunnel and floor 'flanged' around the transmission. At some point it may be easier to do your own floor 'tin' especially if the old floor is cut out. With that said it's difficult to duplicate the 'shear-plate' strength of the factory floor in consideration of weight and integral strength.
You probably have unlimited firewood on your propertyI also enjoy 4 seasons. Do you have a source of fire wood? A wood burner would make a fantastic source of additional heat.
I've been meaning to ask what are performance expectations with the 470? Hoping to get to the 9.90s?They're developing the csr shield which is carbon fiber from the front bell to the case. If you have a blanket it's good to 10s, the steel flex plate shield is additional and necessary for 9s.
Together they're good for 6s
I'd be happy with 10.00ish for now. It may run in the 9s but I'm building it to be 8.50 cert chassis.I've been meaning to ask what are performance expectations with the 470? Hoping to get to the 9.90s?
I was hoping in my 451 effort. But stuck in 10.20s. (Single carb, N/A) I'm setup for a shot of nitrous. But have no experience with. Plus it makes me feel that I'd be using "Cheater gas" lol.
My Duster chassis is not set for anything under 9.90s anyways. I'm guessing your Dart simular?
Hell of a build Sean, very very nice work.You can still do your mods without a blanket and allow the expected room. If you look for the build pics of my car I have a ton of tubes in my floor and it's still light. I also have the tunnel and floor 'flanged' around the transmission. At some point it may be easier to do your own floor 'tin' especially if the old floor is cut out. With that said it's difficult to duplicate the 'shear-plate' strength of the factory floor in consideration of weight and integral strength.
Do you have a build thread on your car ?I've been meaning to ask what are performance expectations with the 470? Hoping to get to the 9.90s?
I did at sometime. Got tired of talking about. So I surf and live vicariously thru others efforts. Lol. But essentially 451 12.4:1 comp on E-85 metered single 1050 (4150) carb. B1/BS Heads. Cam is nothing too hot at .585 lift mech flat tappet.Do you have a build thread on your car ?
