I remembered a std port BB combo I tested that made over 700hp.
From over 20 years ago…….
528 built with a Megablock, 14:1cr, B1-BS heads with basic port job(320/250), 280/280, .690/.690 roller, MP TR(not ported) with 2x750DP’s.
I don’t have any sheets for this one, but I’m remembering it as around 730hp, with it peaking around 6k.
In a 3700+lb 68 Charger it went a best of 9.71@140.
That was with ladder bars.
With Caltracs it went like 9.86@139.
We started out on the dyno with an M1 single plane and an 850DP(probably had a spacer too)…….I don’t remember the numbers exactly, but it was solidly under 700hp.
In my mind, nowadays the “easy button” for 700hp+ from a 470 would be the TF270’s and the Indy 4500 intake on a 12:1 short block.
If keeping with the std port theme, nicely ported Indy SR’s or Victors will out flow the TF240’s by enough to matter(of course, the TF’s could also be ported “more”).
Even with the std port opening heads I’d still run the Indy manifold, and live with the port mismatch.
The sr’s and victors can easily facilitate the MW opening, so I’m referring to the 240’s when I’m talking about the mismatch.
I’d get the 240 heads as close to MW as possible, then live with the mismatch.
For a “true” std port combo……single carb…..the TF or Victor intake with a bit of clean up work should get it over 700hp.
A Weiand or MP TR would pump up the peak numbers some, but will likely peak earlier.
