DEVIOUSDUSTER
Proud Member
John completed the final assembly and then did a final check of the instrument panel to make sure everything would be "plug & play" when it came time to install it in the actual car. His bench test equipment actually fools the instrument panel into thinking it's in the car. It tests all the light functions: night driving panel lights, brake light, oil light, high beam, left & right signals, fuel, temp and amp gauges at low, mid and high scales.
With all the pictures and data John provided, I had every confidence in the world that everything would work as it should (or better) once back home. I was right.
