700 Hp on NA pump gas
THIS is the high bar:
Product Description
This is a fresh built Dodge Mopar R5 P7 Nascar engine that will run on pump gas and has been modified as a wet sump engine. No dry sump pump or oil tank and lines needed for you car. Professionally assembled here at Eatmon Racing Engines. This engine has NEW CP pistons, NEW Total Seal rings, NEW Clevite bearings, NEW Cometic gaskets, MSD dual pickup distributor, Dodge R5 block, NEW spark plugs, Del West coated titanium intake valves, NEW PSI roller cam valve springs, NEW Callies Ultra connecting rods, NEW Stock Car Products 1 stage oil pump, casidiam coated wrist pins, New belts. All other parts are used but inspected and still have more life in them. It has a Winberg 38lb crankshaft, Moroso custom wet sump stainless steel oil pan, Competition Cams custom grind roller camshaft, Jesel .937 keyway roller lifters, Jesel belt drive, ATI balancer, CV Products billet hi-flow fuel pump, CNC ported P7 aluminum cylinder heads from top Nascar team, Edelbrock ported intake manifold from same team as heads, T&D shaft mounted roller rocker arms, Del West titanium exhaust valves, locks and retainers, Smith Bros 7/16" pushrods, Dodge aluminum valve covers. It is 358 CID and 10.5:1 compression ratio and makes 743 horsepower & 540 ft-lb torque. We can supply headers, clutch, bellhousing, flywheel, starter, alternator if you need them. Buyer will get build sheet & dyno sheet,
I argued this some years ago and it occurs to me I might be in the same situation here. When someone says "pump gas" I make the assumption that it's gasoline, or a 90/10 gasoline ethanol blend that anyone purchases out of a pump at any quickie-mart or gas station anywhere in the country. Not the "pump fuel" lower octane race fuels that are carefully formulated and bought at the track. So to clarify - where is the OP on that?
Based on 92 octane pump gas with an 8-8.5 DCR.
Product Description
No this is what you need to buy or build. 700 horse on pump gas without a power adder takes this kind of technology.
A R5P7 motor will need a diffent bell housing no stock bell will work with this block your going to need a tublar k member because of the dry sump custom made headers a 6500 convertor is not going to be street friendly you will not find a better motor for sure they a very trick motor make sure to buy one complete because each builder did things different I'd call Ernie Elliot by the time your done with the motor trans front end headers dry sump plumbing lines your looking close to 18-20 k if your paying 13 k for the motor I've already done this build so I know what it takes
that`s funny, I read not a dry sump engine !
OK so here is another question:
How does an R5 bell housing differ from an R3 bell housing? Or for that matter an R1 bell housing?
Where can I get dwgs for these?
There totally different go over to moparts and look up leon hudson he sells everthing you need for the transmission
I'm still thinking more than airflow or block or fitment - the pump fuel as I understand it just won't let happen.
We broke in my 434 on Renegade Crate 98 race gas, checked the valves, made a few pulls to get the jetting and timing right. After all this was done and we had the best results on the 98 we pumped the fuel cell back into a can, drained the bowls then refilled the fuel cell with pump 93. After warming up on the pump gas the first pull was 30 more hp than the race gas. I thought it was a fluke so they cooled the engine down and made another pull, 30 more hp again.
Your mileage may vary.
I was thinking a 470 small block on pump gas
You get to a point of diminishing returns on inches if you have a small head. Liking drinking in air through a straw.
No matter the size motor, its going to take W8-W9 or perhaps the new Victor heads to make 700 on pump gas
NHRA pro stock motors are 500 inches. They are only roughly 3 tenths quicker than 900 inch mountain motor pro stocks.
So cubes wont solve many of your issues. Just move the powerband down
R3 blocks are getting hard to find so you will have to figure out if your going to run 48 or 59 degree lifter angle short deck or tall deck best of luck on your build
Your going to need something like this to make 700 hp on pump gas
