blue missile
THIS is the high bar:
Product Description
This is a fresh built Dodge Mopar R5 P7 Nascar engine that will run on pump gas and has been modified as a wet sump engine. No dry sump pump or oil tank and lines needed for you car. Professionally assembled here at Eatmon Racing Engines. This engine has NEW CP pistons, NEW Total Seal rings, NEW Clevite bearings, NEW Cometic gaskets, MSD dual pickup distributor, Dodge R5 block, NEW spark plugs, Del West coated titanium intake valves, NEW PSI roller cam valve springs, NEW Callies Ultra connecting rods, NEW Stock Car Products 1 stage oil pump, casidiam coated wrist pins, New belts. All other parts are used but inspected and still have more life in them. It has a Winberg 38lb crankshaft, Moroso custom wet sump stainless steel oil pan, Competition Cams custom grind roller camshaft, Jesel .937 keyway roller lifters, Jesel belt drive, ATI balancer, CV Products billet hi-flow fuel pump, CNC ported P7 aluminum cylinder heads from top Nascar team, Edelbrock ported intake manifold from same team as heads, T&D shaft mounted roller rocker arms, Del West titanium exhaust valves, locks and retainers, Smith Bros 7/16" pushrods, Dodge aluminum valve covers. It is 358 CID and 10.5:1 compression ratio and makes 743 horsepower & 540 ft-lb torque. We can supply headers, clutch, bellhousing, flywheel, starter, alternator if you need them. Buyer will get build sheet & dyno sheet,
Product Description
