Do you think I should pull it back apart to see if the seal is twisted up or should I just air check it? When it was going in it’s was getting hung up and I had to force it, on three occasions to get it to go all the way down.If you keep snagging it, put a tight rubber band around it and put it in the freezer for half an hour. the drum too.
