76orangewagon
Just spent the last week finishing up a couple areas that were modified for the lowered stance...I reworked the firewall steering column pass thru giving a more stamped looking piece with a corrected bearing angle. Second, I capped off the shock towers. Third, finished off the transmission tunnel and made a mounting bracket for the center console. And last but not least cut off the brand new AMD tail panel and swapped it out with a 70'-71' panel (thanks Mark) since I was told by a couple diffferent folks that 73' wasn't considered a "real" muscle car....So now even though the title says 73' it will look like a 71'...which means the custom hood will have to be re-engineered since it doesn't follow the flat design....like I said before 1 step forward 2 (or more) steps back. At least all these changes are "small potato's"
