younggun2.0
you need to do a step by step on the rebuild so i can do the 904 i got sitting on the bench for my ladies 65 valiant.
Your gunna laugh some more too. The Master Cylinder is leaking bad and the front brakes are squealing. Sounds more to me like a bearing is going bad..... So while it is down I will be investigating the brakes & wheel bearings, and throwing on a NEW Master Cylinder. :banghead:
x2 up here...:read:I know that since Butch quit doing them in Socal, the lower cost rebuilds have not been as available.
I might start to do this if I can get it going and charge reasonable prices.
Spring Fling is coming up fast and your expected to be there with the Scamp.
There are already plenty of step by step Video's online. The 727 Video's on Youtube and some other ones there also on the 904. Between those videos and another DVD floating around there is enough info.
Put it this way..... If I can pull it off you can too!
playing hard to get I see,
No way..... The reason is I don't have a video camera that will last while I do it. I have my Iphone but I would need a stand. Plus it is a messy job. Need 2 people to do a good video and I roll solo..... haaa
Whoever worked on this car was a TOTAL BUTCHER.
i will send you a case of beer and a iphone charger. you can lean the phone against the beer and plug the phone in.lol anything else i can help with?
Well I screwed up....:banghead: But at least I caught it! CRACKEDBACK to the rescue again! Haaaa I put 1 too many Steels in it. Clearance is good to go no shaving required at .071" 5 Clutch pack is ready along with the Rear Clutch Pack. They are coming apart and getting soaked for 30 minutes and re assembled!
glad i twisted your nipple enough to do the step by step. looking good teacher.
Lol, with a first mistake out the gate like that?....... haha, I am teaching myself!
thats the best way to learn man. i have watched alot of videos online on rebuilding these trans. and i always think to myself "that dont look that hard, I could do that". but i know as soon as i got it all apart and spread out it would get pretty overwhelming in a hurry.
It is really not bad at all..... EXCEPT the F$*&!! Kit I bought has the wrong size washers for both sides of the planatary gears and they only gave me 2. So I am short 4 cause they are the wrong damn size. Now I am at a stand still until I get the correct chittttttt from them. That kind of stuff gets me pissed off in a hurry. I bought a complete kit and the **** dont fit and its short..... Ughhhhhhhh , I would have had the whole damn trans put back together tonight! :banghead:
I got both front and rear servo assemblies in along with the Sprag, Reverse Drum and band, output shaft assembly with the governor/Reverse gear etc then I had to stop....... Did I tell you now much I hate it when you buy the parts and they don't fit and they are short??:banghead:
