bad440
everything,all the time..
same here louis, i will be wrenchin on my p o s too.driveshaft loop install.nuetral saftey switch is hooked up now too....
I just used those on my BB and HATED them.... Seem to pinch big time between the mount and the steering box and again with the dip stick tube. perhaps a SB will be different.
Mad, what carb you running on the 410?
That's an 850 DP. Just was rebuilt with all the good stuff. Floats, billet base plate, non stick gaskets, alcohol diaphragms etc. Bought it from fishy68 like that. I will be changing the rear floats to V notch and adding jet extensions which only takes a few minutes.
Cool, was just curious....got an 850DP with the choke horn milled off and the ventury blended going on my 408...just trying to get an idea of carbs guys are using on their strokers.
What were you running on it back when it was in the 70?
what jets you running 66s with no pv? doh!That's an 850 DP. Just was rebuilt with all the good stuff. Floats, billet base plate, non stick gaskets, alcohol diaphragms etc. Bought it from fishy68 like that. I will be changing the rear floats to V notch and adding jet extensions which only takes a few minutes.
Lots of work to do before Friday. You gonna make it?
Sounds good. Keep us updated (we know you will) because I only plan on going if there's a group of us.
You didn't street race did you?:burnout:Yeah I went out there by myself last time, was front and center on the main area. Went to leave and I got picked on by quite a few cars with the Lil 340. Had some fun for sure!
