No. I believe it's the one in post #15.Since you have the manuals, would you see if the diagram in post 11 appears in the electrical service manual. Thanks
WoodgrainEvidently someone thought it was from the factory service manual, when it's actually an aftermarket wiring diagram.
Also is your instrument cluster black or woodgrain color.
YesCluster is on the bench, harnesses in the car?
Checks good.Check for continuity between R16 and A11 at the cluster connector.
