Matts440
Is it only going rich when the meth kicks on?
Actually right before, but the meth definitely makes the mix richer.Is it only going rich when the meth kicks on?
Here's a log of when i hit 11psi. You can see where the afr dips to 10.1. The EGO correction looks like it's taking away fuel but it's configured to only adjust 25% so it may not be able to take enough away. What my tuner said may make sense as well. Some other factor is influencing this because the same tune (VE table and AFR) was working fine a few weeks ago and never went this far rich. I just got some fresh E85 and measured it and it's E85 on the dot. I have a fuel pressure gauge but it would be better if I was inputting that fp into the MS so I could log it and see exactly what it is at different boost levels. Those were the two variables my tuner thought might be at play; fuel pressure and E85 mix.Did you miss my question a few posts ago?
When I ran the log against the tune it’s sitting mostly in just two VE cells when it goes rich which are higher than the adjacent ones. One of my strategies is to pull a little fuel from those two cells and see how AFR responds.thanksIf you make a change in the ve table can you make it trend lean? Seems if it was an outside variable you wouldn’t be able to correct for it. But if you’re targeting 11.6 and it’s running 10:1 the ecu will pull fuel and try to correct it. I would make a large percentage change in the ve table across a few cells and see if I got a change. Maybe pull 10% and run another log.
No idea on the valve train noise source. Hoping it’s a loose rocker and nothing deeper then that but it’s hard to pinpoint. But no over reving. I have both rev and boost limiters enabled and they work instantaneously on the Megasquirt. The boost limiter is set to cuts fuel and spark.Sucks about the new valvetrain noise, do you have any guesses what caused it? Over rev it at all? Your fuel pressure spiking has my brain hurting. I see a lot of “not enough fuel pressure” but rarely do you see a spike large enough to move the afr very far. What regulator are you using?
8AN feed and 8AN return at the FPR.How are you returning fuel? That could cause a spike also if the return is too small or restricted in some way.
Glad you found it. I have boxes of lifters if you need some spares.View attachment 1715718606 Collapsed lifter, on the right.
