FelPro 1008What head gaskets are you running on this build?
FelPro 1008
FelPro 1008
What rpm are you shifting your car at. ThanksFelPro 1008
5500ishWhat rpm are you shifting your car at. Thanks
In the middle of rewiring the ECU to engine harness via mil spec type connectors. Moving slow, as usual. Pics to come.@subcom any updates? You’ve been kinda quiet lately.
This is the general idea of the rewire: Two mil-spec Deutsch connectors poking thru the firewall. ECU, relays, bus-bars, etc will all be mounted on a 12" square alum panel. The panel is secure with two Dzuz 1/4 turn screws on tabs I'm welding to the inside of the glove box. The back of the alum panel will be secured similarly. The idea is to make it as accessible as possible with the ability to pull the whole panel out and intact with quick disconnects and keep it up and out of reach of kicking feet in the passenger area when installed.
Yes it is.WOW!
Is that the factory mount for the wiper motor?
Drove down to the track and got three runs in tonight. First one was a wash. I had the overboost protection too low and the fuel and spark cut off at 10psi. So I increased the overboost, turned up the boost controller and on the next run smoked the tires all the way down the track. I hit about 16-17psi and it was a wild ride trying to keep the car straight. Crappy vid a friend made for that run. The 3rd run I turned down the boost but still skated out of the hole and couldn’t really hook. Ran a 7.60/102moh
https://youtube.com/shorts/siehkA6_CQk?feature=share
Haven't had a lot of time to tool around on the car with work but have added a few new gadgets to the Megasquirt - I installed a flex fuel sensor, transmission speed sensor (mph) and a good fuel pressure sensor to help me debug this nagging issue I've had with the AFR going really rich in boost.
Trans speed sensor:
Flex fuel sensor with -6an fittings.
fuel pressure sensor:
Now that I have accurate fuel pressure data I've logged runs with and without the 1:1 boost reference connected and it seems my issue is somehow related to climbing fuel pressure under boost. AFR is much better without the boost reference connected, but obviously that's not a long term solution, especially when turning up the boost. So, I rebuilt the fpr today (new diaphragm, Aeromotive 13001). I've cleaned both filters but am still seeing AFR drop off the data logs (below 10.10) when getting into boost. My base pressure is 58 and of course it hovers a little around 50 at idle with the vacuum removing some pressure but the logs show it rising at pretty much 1:1 with boost so I believe the fpr is working as designed. Just can't figure out why the AFRs fall off the log. In a longer run it will eventually come back to targeted AFRs under boost so I know my VE table is accurate. Any thoughts/ideas guys?
fpr boost reference connected: You can see where the AFR drops to 10.10 at 7.1psi
fpr boost reference disconnected:AFR is 11.00 which is the target, 7.1psi.
