833 4spd repair advice
I'll bet this is your problem now.
I don't quite understand yet what were looking at here believe it or not lol, but is that just out of a service manual or? I will have to read up more to properly understand what needs to be done.
In an earlier post you said:
"Apparently the reason it wasn't going into 1st was because there is a linkage that closes off first and second when reverse is engaged and it wasn't disengaging.
Had the trans reinstalled....now it doesn't go into 1st again....
Called him up and he suggests I simply have to adjust the linkage to get that reverse to stop closing off 1st gear..."
That is the linkage your mechanic was speaking of. And yes, it is in the FSM. The note to grind the ramp is my note when you get into a case that the FSM procedure doesn't work.
Probably not the factory shifter, but adjustments are basically the same.
Good advice 6paxbee.
