There's a recipe in there but it's hard to sort out of the conversation.I would have already done it but well.......you know.
O.K. My 340 I built in 1977 and on a major budget just out of high school. I had been collecting 340 parts and had a lot of low mileage parts. I had a perfect std bore 69 block, a perfect crank, and with the help of a friend that was a engineer at Chrysler and a racer I put together a nice 340. It had full groove clevite micro babbit mains, micro babbit rod bearings, stock crank, my buddy did the rods opened up the big end so it would have .0035 clearance then cut .001 off the caps, we had .0025 top to bottom on the rod and .0035 on the sides. Now you can just buy bearings with more side clearance but not back then. 10.5 :1 pistons std bore, 400 grit finish, moly rings .040 + 5 file fit Chevy rings, 1/3 the price of mopar rings. X heads pocket ported with a full radius seats, my buddy made his own stones on a fixture he made at Chrysler. Stock 2.02 1.60 valves, dual valve springs, MP cam .572 .296 mechanical with crane ductile rockers, Hooker 1 7/8 super comp headers, MP mechanical 6 pack carbs. Ran 11.84 114.9 MPH in a 64 Barracuda shifting at 7600 RPM
727 Turbo Action VB, 4200 stall TA converter, 5:13 Dana 60 w/spool
Thanks. I have that one above along with 1.6 rockers waiting to go.
No discouragement taken, that's why I posted this ! In my mind it sounds awesome, reality is another thing.I want to make it clear I not trying to discourage the OP from doing what he wants.
I'm trying to open his eyes to what he is really wanting to do.
Again, it's not a small block Chevy. Not only is the oil timing off, the valve train geometry is junk, on both sides of the rocker arm.
And if he doesn't address those issues, he will burn through his money so fast he'll be bankrupt so fast he won't know how it happened. Unless he is incredibly wealthy, and even then it's still a HUGE expense and a vertical learning curve.
If he's will to spend the money on a Ritter block which has the oil timing corrected, and get the lifter bank angle down to 48 degrees, and use a head that has valve gear capable of that RPM (and it ain't using stands with saddles in them) then I say go for it.
If he's not willing to do that, then he needs to reconsider his options. Like build 400 inches and turn it 7000 and make sure he does it with 340 mains and go smoke some ricers and Chevy junk.
Maybe I'll just stroke the 71 340 block I have, put the eddy rpm heads that are currently on my #'s engine and see where that gets me .... I'm sure plenty to have fun ! Also keep it running on 93 octane
You'll be 2k rpm short of your original goal but will have gobs of torque. Can be equally fun, enough cylinder head provided.Maybe I'll just stroke the 71 340 block I have, put the eddy rpm heads on
Can you clear your inbox out, or call me?Don't have a number in mind honestly, just want it to hold together !
This all stems from a guy near me with a 327/4spd 55 Chevy. He drives the **** out of his car, shifts at 8k everytime he drives it. Sounds amazing!
My inbox is clear !Can you clear your inbox out, or call me?
Ok, don't beat me up on this one. No I don't race, I know it's completely impractical .... thinking of rebuilding the engine in my 70 340 swinger in the near future. Will be putting the #'s matching engine in the corner of the garage, I have a complete stock bore 71 340 that I'd build. My problem, I want 8k rpm. Want to build a fun, high revving engine for around town pleasure. Not sure why 8k stands out to me but it just does . My question is, how attainable is this and how much work are we talking about so I don't worry about sending shrapnel outside the engine block everytime I get on it ?
No I don't race. you answered the question yourself. It is not practical to build an 8000 rpm 340 street motor.Ok, don't beat me up on this one. No I don't race, I know it's completely impractical .... thinking of rebuilding the engine in my 70 340 swinger in the near future. Will be putting the #'s matching engine in the corner of the garage, I have a complete stock bore 71 340 that I'd build. My problem, I want 8k rpm. Want to build a fun, high revving engine for around town pleasure. Not sure why 8k stands out to me but it just does . My question is, how attainable is this and how much work are we talking about so I don't worry about sending shrapnel outside the engine block everytime I get on it ?
Sorry, no converter needed with a 4spd .......Guys want an 8000 rpm engine and then run a 3000-3600 stall convertor. Lol.
