The goal of the KD mechanism is to get that lil lever down on the trans to go, all the back as far as it goes, when the throttle is at WOT making sure that the gas pedal actually gets the throttle to WOT.
In this position, the throttle pressure will delay the governor-commanded upshift, for as long as possible. Sooner or later, the governor will win the pressure battle and an upshift will occur.
If it happens too soon, it because governor weight is too heavy, or spinning to fast.
If it happens too late, it is because it is NOT heavy enough or spinning too slow.
Just fix it.
Once the governor pressure is in the ballpark, you can fine tune the actual shift point with the KD mechanism.
If the day to day shifting is too harsh, then the balance between Line pressure and throttle pressure will need to be tuned, which may require revisiting the Governor pressure. and ultimately, it may happen that the PT kd fails to work pleasantly, and then, that will have to be recalibrated. So, the pan is gonna be off a few times, so stock up on gaskets and put a couple of studs in the rails to guide the pan home.
AND, drill and tap a place in the case, thru which to reach the line-pressure adjuster with an allen wrench.
And to top it all off, if you have a carb with a tiny primary throttle, you may have to dick with the KD ratio, cuz that sucker is always open further than it would be, with a big-primary throttle.
Here is an understanding that nobody ever told me, and I give it to you for free;
1) the governor pressure sets the stage for all upshifts.
2) KD pressure joins with Line-Pressure to delay the upshifts.
3) Line pressure alone fights Governor pressure, whenever the KD is relaxed.
4) if adjusting the KD does not produce the desired result, and the thing is working, then you can bet the Governor pressure is wrong.
5) swapping more than one gear size (10%), will almost always need an accompanying governor change. Swapping 15>20% for sure will.
Going from 2.7s to 3.5s is ~29%. Yeah that's a big change in driveshaft rpm .
6) once your governor is in the ballpark, you get to fine tune it with springs and clips, or the disc grinder lol. Somebody shouldda, years ago, cast us an extension with a governor access hole; or made it like a Chevy. I thought about it one day ................. But after I pulled it a few times, on a 4-post lift, the wrenches all seemed to find their way around .
