AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,916
- Reaction score
- 12,266
ouch
yep still charges that or more from his house , got 1 sitting in the corner of my garage , it's the reason I rebuilt my 904 myself .ouch
Yup, and those old converter flushers were about as effective as now going to a lube shop to get your transmission flushed. Yes, it will get rid of the old oil, but cold solvent could never get the crud out of the vane areas. The most effective cleaner is hot ATF.Wow! that's a lottacoin for a couple of hours work.
I have convertors from the 70's that I'm still using, although none were involved in serious meltdowns. Transmission shops used to flush them for a small fee.
And you could get a beer for 25 cents., and my brand new 71 340 Duster cost around $3100.00 or so on the road.I used to build them for $100Can plus parts, and $100 more to RnR....... back in the 70s,lol.
I bought my slightly used 1970Swinger 340 4-gear in late summer of 1970, at the tender age of 17....... with half the money coming from my piggy bank of paper-route earnings. It had 11,000 miles,the tires were new appearing, she was Panther Pink, and I talked the newly become Dad, down to $2400Can.And you could get a beer for 25 cents., and my brand new 71 340 Duster cost around $3100.00 or so on the road.
First timers might be overwhelmed by all those different parts. Rebuilding a 904 is a good experience for the first time, but that much disassembly is more than I would recommend for the first timer. I wouldn't remove the governor support or rear band anchor or even the tailshaft housing. And I wouldn't disassemble the valve body either. 9 out of 10 904 trans lose third gear and have a delayed reverse. Or they slip going forward. Those two drums are the first out after the pump. And for a /6 904, I would seriously consider installing V8 drums, or at least use lower ribbed forward pressure plates as top plates on both drums. And when you assemble the pump, use a giant adjustable hose clamp to align the two sections.
The most important wear parts haven't even been disassembled in the pics. You can't inspect clutches without removing them from the drum. So far it's just a band and direct (not forward) drum. The forward drum has the shaft. The direct drum sometimes called the "front" drum is mistaken for the "forward" drum. And to make matters worse, some people call it the "frontward" drum. You'll find terminology all over the board so never trust that.
So far. Clutch clearance is critical and different manufacturers make different thickness fibers. Count the clutches. Thin smooths are forward and waffled are direct. Might be too burnt to identify. And always check endplay before you remove the pump so you have some idea how big to go oversize thrust washers. Too lose and the direct drum wobbles. And grease the center pump gear on center.
Because you need a drum anyway and they're the same price; about $35; plus the kit comes with four clutches. Have you even looked in the kit and compared the clutches?
