Pictures of the new Winters Performance aluminum Dana 60 differential with Strange axles for the silver Hemi Duster. This will complete the aluminum intensive drivetrain in this car which already includes an aluminum Griffin radiator, an all aluminum 426 Hemi, a Passon aluminum cased A833 4 speed trans, an aluminum Gear Vendors O.D. and an aluminum Denny's drive shaft. Note: the ends won't be welded on until the 4-link brackets & shock mounts are slid on to the axle tubes.
This rearend, which is rated for 1500 HP and contains a 4.56 ring and pinion, was held up for a couple of months due to Winters designing an supplying it's own proprietary center section after deeming that a Tru-Trac wasn't strong enough.
You might recognize the Winters name as a major supplier of quick change rearends over the years for midgets, sprint cars, champ cars and street rods. Winters also offers complete rearend packages for stock cars such as ARCA and NASCAR.
