PanGasket
has cork sides
I'm trying to delete my A/c system on my 318 and I have the crank pulley, the alternator bracket and the water pump pulley. It seems like the alternator bracket wont fit right at all. the lower jaw piece seems to stick out way further then it should. Is an A/C water pump gonna cause this? would my bracket and alternator line up right where they should if I was using a non-A/C water pump?
Also, does it matter than I am using my A/C alternator with the 2 groove pulley? I didnt think it would as the groove closest to the alternator looks to be the same distance as one with one groove.
