A different Q on 340 Vs 416
Yep they are much better at scattering needles all through your motor they like to be kept on the lobe and especially do not like valve float
Runing a sensible streetroller and keeping some kind of eye on the valvespringpreasures and thats pretty much a non isue.
That's why I started using hydraulic roller lobes with solid lifters and setting cold lash at .002 and let it run.
Alright thats one way to do it,but why not just run a sensible street solid roller at that point and get more lift for the same duration? alot of Comp XE solidrollers out there doing alot of miles with no isues and i believe those Lunati wodoo cams seem to last quite good aswell and both series run reasonable lash.
yeah it's loose lash and valve bounce/ float that kills them
Yeah loss of springpreasure is bad news for sure,much worse than on a flattapet.
Because the street rollers don't like to be lashed at .002 so the hydraulic roller lobe is quicker off the seat.
Besides, what they call a "street roller" lobe today is nothing but a 1988 "race" lobe.
