Jarlaxle
Troll on, dude.
Troll on, dude.
Got. You don’t know why it’s right or wrong. You don’t have an answer.
I’ll say it again so anyone who comes along can learn for themselves. Rating a transmission on torque is a idiotic as buying a cylinder head based on flow numbers.
Simple as that.
That's how all of the T5 transmissions are rated, by torque. I'm listenin if you care to splain.Got. You don’t know why it’s right or wrong. You don’t have an answer.
Simple as that.
I do know...but you don't care...so I'm not going to bother.
But by all means: put a transmission rated for 300 lb-ft behind a 440. Torque capacity doesn't matter, so you should be fine, right?
Thanks. I understand your explanation.....and agree with it. If the torque "has nowhere to go" it will make a path.......through broken parts. But to say that 300 LB FT is "anemic" is a blanket statement, no? 300 LB FT is "pretty good" for instance, for a slant 6.I already did somewhere, but I’ll explain it again. It’s simple really.
You can take any transmission and apply this to it, but because 300 foot pounds is the number in this thread, we can use that.
It doesn’t take much to make 300 ft/lbs does it? Let’s take a 273 2V engine. I don’t know what it made for torque, but I could look it up. If it’s 300 that’s all it is. That’s only 1.099 foot pounds per cubic inch. Pretty anemic.
So let’s drop in that 300 ft/lb gear box and let’s leave the 7 inch, rock hard pizza cutter tires on it. There is no way you’d ever break that gear box with that combination. Long before the gear box broke, youd smoke the tires.
Along that same line, we drop a 408 in there and it’s now making 500 TQ. That’s what? A 66.6% increase in torque. It’s the same thing. Long before the gear box breaks, the tires smoke like a chimney. So how does a torque rating make any sense?
Throw some bite on the 300 TQ combination and unless you can turn the tires it will break the gear box. Now add in a parts breaking clutch and you just made it worse by an order of magnitude.
Along the same lines, we can follow it up with a different example.
I have no clue what an A833 is torque rated for because I’ve never seen a number published. For the sake of the argument I’m sure it’s at least as strong a TKO60 which is rated at 600 TQ.
Let’s take a 340, making an honest 450 torque in a 2800 pound car. The A833 should be more than strong enough. So should the TKO60 box.
That same 405 TQ, 2800 pound car has a set of 14-32’s on it and let’s say a Ram 3 puck clutch. It’s highly unlikely that will spin those big steam rollers, especially in 3rd gear down the track. 3rd gear is the weakest gear in the transmission.
You bang 3rd and crap 3rd gear so fast you can’t get the clutch back in. Was the gear box rated too high, or did a big tire and a parts breaking clutch kill it?
I’ve seen guys miss on their clutch tune up and break Top Loaders and about every brand you can think of. I’ve seen one Liberty get hurt, but that was low gear. I’ve seen a couple of GForce G101’s get killed by engines that were nowhere near the torque rating.
My point is that torque is a piss poor way to rate a gear box. It’s basis is in marketing not in fact. It’s a simple way for the manufacturers to establish some arbitrary number to scale so the average guy can think he has a way to compare transmissions.
It’s like comparing cylinder heads by CFM and totally ignoring port size and shape.
Transmission torque ratings mean very little. Buying a transmission based on a torque rating is like buying a cam based solely on seat to seat timing. It ignores the big picture.
Simple as that. Make the tires spin and you can run a very low rated gear box. Put some bite to it, add a lock up clutch in front of it and then drop the hammer on it and you can’t buy a good enough transmission.
I agree normally it would, but I ain't normal.So you mean 300 itself is anemic? It depends. For some engines it may be a very good number. For a 500 inch engine even in a mild state of tune, 300 would be an anemic number.
I was using that number because that’s what was thrown out there and for 99% of what gets lit around here, 300 would be a pretty low torque number.
Engine torque is something most car guys think they understand, so giving them transmission torque ratings to compare preemptively answers the question at the top of most lists. Turns out whether a transmission lives or dies is more complicated than just engine torque, but the transmission manufacturer has little control over those other variables. Hard to fault the them for throwing a number out there anyway, as they are just trying to satisfy the masses.
Grant
I sure wish my wife's grandfather was still alive. He worked in the dyno room at New Process Gear all the during development and at least the first decade of production of the A-833. I'm pretty sure he could set us straight in industry standard terms. He passed away relatively young, forty years ago, two years before I met my wife. His daughter, my mother in law, always said we'd have gotten along very well.
Somewhere I read that a major determinant of transmission torque capacity is the distance between the countershaft and mainshaft. So boxes with higher (lower numerically) first gears tend to be stronger. Can't find the source though.
I remember watching road kill garage (season6 episode3) when Dulcich put a paddle clutch in the cougar and thinking here we go!, split the toploader case in half with a sub 500hp 363 small block and street tires.Here you go. Read page 3 very close. https://www.jericoperformance.com/break_in.pdf
There is another set of instructions I can’t find for clutch assisted gear boxes. Simple reasoning says if you can’t lock up a clutchless box that goes into the next gear before it comes out of the lower gear, you damn sure can’t lock up a clutch on the shifts and not kill the box.
In a clutchless gear box, the slider goes into second before it disengages from first. Same as you go up in the gear changes.
Have you ever seen a torque rating for the 833? I’ve looked and I have never seen one. It would be interesting to know how Chrysler rated the 833.
I do know years ago I read an article on the 833 and how at least part of it was developed. It said they would build the transmission and then flog it until it failed. They would fix that failure and then flog it again until it failed and fixed that.
I’d love to find where I read that, but that was some time ago and I have no clue where it came from.
Some people are just not comfortable hacking structural parts.People should just no longer buy them, it's that easy.
The Tremec T56 Magnum swap has been done enough times now -> just forget about ever returning the car to stock (you're not going to anyway), do the ToddRon crossmember and the T56 Magnum, proven stuff, liberty can face plate it, whatever you think you need. It's even the Chevy LS transmission so these will be around forever. Once you get the crossmember in and the floor figured out, the rest is frankly very easy.
