jet_wrnch
Active Member
Ok, here is what I got
I have one hell of a bogg when Im cruising and lean into it. Im running 36 degrees of timing; the carb is what Im leaning towards. Ive checked the power valve (4.5) and tried using different pump cams. went from 70/82 jets to 66/80 Plug gap @.45, getting 8-10 hg of vacuum at idle. It starts and idles fine. If I get after it right out the hole it does fine. Its only when Im rolling at cruise and lean in to it falls on its face and then pulls out of it. Its not backfiring just stuttering. Any Ideas before this car ends up in a dumpster????
408 with eddie heads, airgap intake, 750 aed carb, big cam,complete msd ignition. 4 spd, 323 gears
